PDA
View Full Version : Performance
Pages : [1] 2 3 4
  1. Black Bear Tune nearly done...
  2. CAI's
  3. Best Exhaust System????
  4. Intake Manifold
  5. Crank re-learn not working...EFI experienced guys come on in
  6. Spectre 9900 CAI $106...take a look
  7. Muffler/Exhaust Suggestions???
  8. 5.3 vs. LS1 what is the difference??
  9. Question I just gotta ask about the 5.3
  10. Vette servo???
  11. Engine Swap??? LS1
  12. got exhaust done on the yukon
  13. Cam swap or mild nitrous shot?
  14. Prep for a custom PCM dyno-tune?
  15. Raced a modded 6.0 Powerstroke
  16. The Engine Mod Thread
  17. Electric Fan
  18. Nice Yukon on Youtube...
  19. my buddies '67 Nova
  20. Transmission Trouble
  21. Challenge: Put this together for a Tahoe!
  22. Shift kit/servos/stall are in and it runs! Pics
  23. Hypertech Help!!!
  24. Cold Air Intake Installed
  25. Anyone have exhaust cutouts on?
  26. can we get some usefull CAI info going?
  27. Exhaust Systems- Reviews
  28. does the 4.8l CAI fit the 5.3l
  29. Post up your Exhaust videos/sound clips
  30. Throttle Body Spacers
  31. Question Regarding Diff Fluid Change..
  32. LS1 Engine Swap
  33. Programmer
  34. header..
  35. OEM MAF size... WTF?
  36. Programmers - NOT CUSTOM
  37. Home Depot'd my CAI and dropped my IAT 20 degrees!
  38. another E-fan thread
  39. exhaust tip
  40. Transmission Oil? and Cooler?
  41. Exhaust: Was what I thought true?
  42. Tranny spraying fluid after installing vette servo
  43. Pre-filter for Volant CAI
  44. list your mods and 1/4 ets and traps. please.
  45. Transmision FS??
  46. Turbos or Supercharge?
  47. Difference between Transgo reprogram kit and a shift kit
  48. New Videos of the Pavement Princess (Got Boost?)
  49. E85????? Good/Bad----Jenna/Justin/anyone:comments
  50. swap out thermostat??
  51. intake piping question
  52. solid engine and transmission mounts?
  53. Efans Installed
  54. Jus got an Spectre Air Intake Kit for $75 shipped!
  55. Headers
  56. Noise from rear diff?
  57. Downside to installing the Corvette Servo?
  58. LT header ?'s
  59. help with my supercharger
  60. If you had an LQ4 to drop in, what would you do beforehand?
  61. 2004 Denali 6.0
  62. Anybody use a jet chip??
  63. motor swap?!
  64. wanna be fast as hell
  65. cold air intakes
  66. Flowmaster? Magnaflow? Help
  67. MPG with supercharger
  68. Thinking about Supercharging
  69. opinions on this ebay efan kit
  70. Question for you E-fan guys
  71. Vette servo problem
  72. servo info needed.
  73. mbrp mufflers?
  74. Rearend problem???Maybe?
  75. Now this is a 5.3 vortec!!!!
  76. Efan mileage increase
  77. Throttle Body Spacer 02-06 Tahoe/Yukon 49.50 shipped
  78. Has anyone experienced this
  79. PLX wideband
  80. Finished a couple of improvements ...
  81. parts have started to arrive
  82. Post your custom CAI setup
  83. 7mm wires or 8.5mm
  84. tuning ?'s
  85. octane booster
  86. The AEM Brute Force is....
  87. Increasing throttle response ??s
  88. cai finally installed
  89. I want to smoke tires W/24'S
  90. gas mileage?
  91. Stuff to complement a procharger
  92. boost gauge
  93. Anyone have Volant Intake and thinking about the scoop? Come in!
  94. seriously thinking about adding the bottle
  95. tune up
  96. Headers
  97. Gears
  98. Upgraded camshaft..what do i need?
  99. wireless remote loss strength
  100. I need a "how to" on removing torque management.
  101. Electric Cut Outs for Exhaust!
  102. MSD Ignition
  103. LS6 Intake
  104. How much is too much b4 I need a tune?
  105. duramax yukon-
  106. Thrush Mufflers
  107. Knock Sensor??
  108. 3600 stall...
  109. Jenna Recommended
  110. Engine Build- Cam, LT's, Heads, ECT...
  111. Aem cai
  112. Programmer Help
  113. Possible Tune Up
  114. air intake
  115. Compression ratio and cam specs
  116. Cam questions...
  117. E fans and altenator, what else?
  118. Vette servo steal!
  119. Black Bear Tune is a most!
  120. Pickin a cam
  121. LT headers w/ stock y pipe???
  122. How much boost?
  123. LT headers and cats
  124. Ceramic Coating Intake?
  125. does any1 know if the make this for our trucks?
  126. Belt tesioner & idler pulley
  127. High Velocity Merge Collecter
  128. vette servo with trans in truck..can it be done?
  129. LPP LT's and stock cats
  130. Does anyone really know about Alts vs PCM
  131. are these good headers for my truck?
  132. Seafoam induction?
  133. What does a big 3 mod accomplish???
  134. LQ4/LQ9 - Everything you ever wanted to know
  135. quick header ?
  136. Seafoam Induction WTF is that?
  137. best hp upgrades for the money
  138. Round 2 of mods - AEM Brute Force installed
  139. SES light on, Help with code
  140. Bank 1 Sensor 2 Low Voltage DTC
  141. Exhaust Vid
  142. Motor Oil
  143. Where should my fuel pressures be?
  144. autolite iridium xp plugs
  145. My 5.3 vs 6.0 evaluation
  146. Eveporative Emission System
  147. Black Bear Tune
  148. MBRP Exhaust Installed
  149. Vette servo problem
  150. exhaust question
  151. Grinding noise
  152. thermostat helps performance?
  153. LPP O/R Y-Pipe
  154. Anyone running e85?
  155. Vette Servo From H#ll
  156. sts turbo
  157. Who built that cool custom intake?
  158. quick 3
  159. Slick 50 engine treatment?
  160. **PICS** My CUSTOM Intake
  161. Vette survo
  162. intake made mpg worse?
  163. Wideband AFR
  164. My kitty died!
  165. Oil pressure staying at 80
  166. Magnaflow for '01 Denali
  167. OEM 05+ Radiator Fans (ELECTRIC)
  168. How many cat's?
  169. Will this Magnaflow fit my Hoe??
  170. Vorteh supercharger
  171. What intake kit and pulleys should I go with? - '02 Denali
  172. Green cold air intake
  173. Official NBS Exhaust thread
  174. Best method of changing transmission fluid
  175. muffler and cold air intake
  176. A little advice needed.
  177. someone please school me on gas mileage and o2's please
  178. Whining on startup
  179. 6.0 liter Long Tube Headers!!!!!
  180. magnaflow muffler vs full catback
  181. BlackBear Tune for Newbie!!
  182. CAI,etc... for 2000 Denali
  183. Cherry Bomb Muffler...Single in/ Dual Out
  184. Shorty Headers
  185. tuneS
  186. engine chug/hesitation..HELP!!
  187. e-fan ??
  188. lt headers and emissions?
  189. CAI Installed
  190. Is My truck ready for B.B.Tune ?
  191. How to improve fuel economy on 03 tahoe 5.3
  192. ATX and Volant
  193. My Escalade ESV turbo build pics.
  194. Engine mods???
  195. Corsa exhaust Avalanche 02-05 fit my 04 Tahoe?
  196. 05 fans
  197. Corsa Inspired!!!!!
  198. alternator
  199. Turndown sound on tahoe/yukon?
  200. Rough idling and bogs down on startup?
  201. AEM filter for my knock off intake
  202. True Duals, 01 Tahoe
  203. Volant Cat Back
  204. Theoretical Question
  205. New Exhaust!
  206. radiator fan wiring diagrams....
  207. SLP exhaust tips
  208. Best Combination
  209. what else is there?
  210. LQ9 (6.0l HO) in a Tahoe
  211. Tranny Problems
  212. 4x4 gears
  213. Anyone have efan harness pics and directions
  214. New dyno for my Denali
  215. Side exit before wheel
  216. Just ordered my Corvette servo
  217. questions re electric fan harness: Nelson vs Black Bear
  218. Hypertech programmer
  219. Anyone have an LQ4 for sale?
  220. Stock trans behind a blown 6.0
  221. Cherry Bomb Cat-Back Install
  222. Anyone ever consider dropping in a Diesel
  223. e fan harness question
  224. Question about Pacesetter LTH's
  225. Exhaust Questions...
  226. dyno numbers
  227. need some solid advice@programers
  228. Transmission
  229. Great find on CL
  230. AEM or K&N
  231. Just ordered these..
  232. Brake Dust
  233. K&N FIPK cold air intake
  234. Out comes the 5.3 In the 6.0 HO
  235. Magnaflow vs Flowmaster - mufflers only
  236. a little acceleartion video of the hoe
  237. Odd coolant / Exhaust manifold Question
  238. 2004 4.8 liter upgrade to LQ9 6.0 Liter Questions
  239. Msd???
  240. Killed a Lexus GS430
  241. Lq4
  242. Magnaflow Exhaust is on!
  243. Rattling O2 sensor
  244. Anyone tried the Powr-Flo Mass Air Sensor from jet performance?
  245. school me on pullies
  246. school me on nitrous!
  247. Need the experts... Long Tube headers
  248. cam in 5.3
  249. swapping gears do i need 8.5 or 8.6 ring?
  250. New Tranny ... Thoughts?
