Driver door courtesy light stays on all the time while all other lights go off properly. Ideas why? I did change the courtesy lights to LED
jraesq
Upgraded all interior lights to LEDs. Started working fine but then the driver door courtesy started staying on longer and longer and now it never goes. Lock the car all the lights go off except driver door courtesy light. replaced door switch and door lock but courtesy light stills stays on all the time. Anyone have this issue? Fixes? Work arounds? I would like the door courtesy lights to match.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me will chime in.
Big Poppa 2006
I have this same problem on my drivers door courtesy light, and no LEDs are being use. Did you figure out what the problem was?
I replaced all of my incandescent lights, inside and outside, and I do not have this issue. It could be related to a defective LED, as @Fless indicated above, so give that a try to either confirm or rule it out as the source of your issue.
Celu0
Have you by any chance replaced the Driver Door Switch prior to this happening?
MBay Mobey
