2004 Southern Comfort
Daily Bread
I purchased this 2004 Southern Comfort Tahoe new and to this day its like driving on a couch .
Its only got 100,000 miles on it and the only things that have been completely changed are the brake supply lines and a radiator , both rusted out and its probably because of non use .
A few cracks in the Southern Comfort plastic outside parts need replacement but other than that the truck runs like new
I change the oil every 4000 mi.
Now I've got a problem with the passenger rear door and I cannot open or close it . I took the panel off from inside and the actuator seems to be working and all control arms seen seem intact and connected . Im guessing the door lock is the problem but since I can't get the door to open ,I can't unscrew the lock plate which is only accessible with the door open . Is there a way to open it ? I've tried everything and the next step is the dealership or a locksmith and that's going to cost this unemployed senior a few needed dollars .
I purchased this 2004 Southern Comfort Tahoe new and to this day its like driving on a couch . Its only got 100,000 miles on it and the only things that have been completely changed are the brake supply lines and a radiator , both rusted out and its probably because of non use . A few cracks in the Southern Comfort plastic outside parts need replacement but other than that the truck runs like new - I change the oil every 4000 mi.
you should be able to just push or pull the control arm and push on the door at the same time and it will open. I open them at the junkyard like that all the time
I’m guessing this is some sort of specially modded by a third party company Tahoe? Never heard of a southern comfort Tahoe. We need pics haha.
Ya there are a few around, no longer in business can't get parts. and unless I am mistaken the owners son started his own business called black widow
*I think they made them up until around 2009, there are a few gmt900's with the body kit rare though
Welcome to the Forum from NH.
Pics of the truck, please.
leschew
